JayJay (152.163.201.209)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 28, 2001 - 2:25 am: | |
I'm considering a Coleman "Park Model" 110V heat pump for my 4905. 15k btu cool, 12.5k btu heat, and draws about 14A. about $850 plus locally built duct work. Yes I know, it won't heat below 35deg.F, but other than that, is there a reason NOT to buy it??? I'm going to use a basement type, whether it is the heat pump or a regular A/C with a heat strip. I heard Carrier Corp. is doing RV stuff now, but no info locally. Anyone out there know anything about that, since I really like their other equipment? Thanks, and Cheers...JJ |
FAST FRED (63.215.236.76)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 28, 2001 - 5:21 am: | |
AS long as you DO realize below 35 or so you will need a different style heater / furnace , why not. Its great to be able to heat cheaply , even when its campground power , and heat pumps work well. There is the problem that cooling with a heat pump is about 10 to 15% less efficent { all those reversing valves ect}, so if you have a darker coach and go to really hot spots, the cooling may be compromised. FAST FRED |
max muston (Radmax) (64.218.228.90)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 28, 2001 - 12:12 pm: | |
jay' ron the busnut has dual compressor heatpumps for $850. these are roughly 30k btu's. he has colman-mach 6636(ac only),6535(hp) and 6536(hp). just ask him. see www.rvcomfort.com for spec's and manuals. linux rulz!!!!!!!!! |
JayJAy (64.12.102.52)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 28, 2001 - 10:36 pm: | |
Thanks troops... the Buffalo is Corvette Arctic White with a narrow black strip along the window line. I'll try Ron, since Jack C. e-mailed with the same info. NOooo Max, it's SCO/UNIX!!! Cheers...JJ |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 29, 2001 - 3:49 pm: | |
anything as long as it doesn't come from redman wa. |
