Rear air plates Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » April 2005 » Rear air plates « Previous Next »
carlmci9
Posted on Friday, March 25, 2005 - 9:18 pm:
I am going to have to block off my rear air beams.. Is there any tips out their before I start this project any trouble areas I should be aware of? Any help would be appreciated? thanks in advance
carlmci9
Posted on Saturday, March 26, 2005 - 12:24 am:
IIRC, the MC9 may have convoluted air bags. I understand that blocking the air beams calls for a change of bags to the rolling lobe type, if you want to preserve a good ride.
I'm going entirely by memory here, so you need to ask questions about this item when you plan to get the work done.
For what it's worth.
Tom Caffrey PD4106-2576
Suncatcher
Steve (Steve)
Posted on Monday, April 04, 2005 - 9:14 am:
MCI has a complete kit to convert it to the rolling lobe air plate block off $850.00 for the rear. They will be happy to fax you the directions so you can see what work you are looking at. Steve at Cajuncoasters@direcway.com
