Oil in steering Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » April 2005 » Oil in steering « Previous Next »
DAVID HEAD (Chuck)
Posted on Wednesday, April 06, 2005 - 7:40 am:
any body know where to put steering oil in an mc9
John that newguy
Posted on Wednesday, April 06, 2005 - 7:53 am:
Here: http://www.dialup4less.com/~aabn/Steering-oil.jpg
It's marked with a yellow outline..
Earl-8-Ky
Posted on Wednesday, April 06, 2005 - 10:17 am:
In the floor close to the steering column there will be a round plate held down with a screw. Take this plate of and there will be a filler plug there. I use 90 wt. oil.
John that newguy
Posted on Wednesday, April 06, 2005 - 10:49 am:
David.. Iffn' ya' don't have a manual, see if this is any help:
http://www.dialup4less.com/~aabn/MC9_docs/
Brian (Bigbusguy)
Posted on Wednesday, April 06, 2005 - 12:09 pm:
I would make sure it uses oil in the gear box not grease. if it has the manual box. I always though it gear oil was used in the manual box type but a lot use a light weight grease.
Brian 4905 Vancouver WA.
bruce king
Posted on Wednesday, April 06, 2005 - 2:03 pm:
the picture above is an 8v71, i've got an 8v71
in my mci 9, and don't have that tube. as you face the rear of the coach, look on the right
side of the engine near the front of the engine itself. You should see a cylinder with a glass
level check, similar to the one that you use to
check radiator water level. if it's dark,
its full. if you can see a spring in it its
empty. The fill on mine is right there
as well; a small twist cap, similar to the one
in the picture.
DAVID HEAD (Chuck)
Posted on Wednesday, April 06, 2005 - 7:27 pm:
Thanks for all the help guys where would one find a manual for an mc9 or is that maybe not possible
John that newguy
Posted on Wednesday, April 06, 2005 - 7:38 pm:
Check the flea market here, David... or Ebay.. Manuals are
available all over for around $50 per. You'd want the MC9
manual, the Detroit Diesel manual and the MC9 parts manual.
All are indispensable and worth the bucks.
Rob King
Posted on Wednesday, April 06, 2005 - 9:52 pm:
David
here is a link for where I ordered my manual on CD. A bit pricey but has all the info on one CD.
http://wwww.coachinfo.com
Rob
Posted on Thursday, April 07, 2005 - 8:21 am:
David,
We have the Parts & Maint. Manuals for the MCI's. For this situation call my friends at Power Steering Specialist' in Ohio 800-235-3076. They may ask some questions so any info you can pull off of the Tag on the power steering box will help.
