Calling all mechanical types Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » April 2005 » Calling all mechanical types « Previous Next »
DAVID HEAD (Chuck)
Posted on Thursday, April 07, 2005 - 4:59 pm:
I removed the dip stick from my steering pump and it was only about three inches long is this the right length and if it is how full do you fill the steering pump.It is in a mc9
Posted on Thursday, April 07, 2005 - 7:57 pm:
Hello David
Put the oil somewhere onto the bottom half and monitor it. Use an awl and scratch a line.
You don't have to worry about it being precise. The level does go up and down a bit with expansion and contraction.
Be sure that you check it with the operating temp the same each time.
And return to your original topic post when you come back with more, don't start a fresh thread.
Keeps the thought processes all together for others to learn too!
James Maxwell (Jmaxwell)
Posted on Thursday, April 07, 2005 - 9:15 pm:
It is the right length and you fill where u removed the stick. 1/4 to 1/2 way up the stick is sufficient.
DAVID HEAD (Chuck)
Posted on Thursday, April 07, 2005 - 10:44 pm:
thanks jim
BrianMCI
Posted on Friday, April 08, 2005 - 9:49 am:
David, there aren't any indicators on the "dipstick"?
Without further information I'd be worried that the bottom part of the dipstick broke off, especially if the dipstick is on a tube as opposed to the reservoir itself...
Brian
Ed/Jefferson bus
Posted on Friday, April 08, 2005 - 3:51 pm:
MC9's have a sight glass on the resivior to check
the fluid level. The cap on the fill tube is just
a swell plug.
DAVID HEAD (Chuck)
Posted on Friday, April 08, 2005 - 9:00 pm:
Managed to put four quarts of oil in the steering box she turns on a fourty acre lot now no problem.Thanks for the help
