Toad angle variance Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » May 2005 » Toad angle variance « Previous Next »
dug
Posted on Monday, May 02, 2005 - 3:51 pm:
I have an MC8 pulling a Durango toad with a roadmaster towbar. There is about 13" difference (vertically) between the bus hitch and where the towbar connects to the durango.
When I contacted Roadmaster, they said they couldn't help. But noted that Blue Ox made a 10" drop.
For those who have come across this issue, what did ya do?
Thanks,
Dug
75 MC8
Arcadia, FL
Jim Bob
Posted on Monday, May 02, 2005 - 5:08 pm:
Is the Durango higher than the bus? Or the other way?
Jon W.
I have a machined aluminum adjustable height hitch. I tow two vehicles of different heights and this works nicely to keep the tow bar level. I bought my hitch through Buddy Gregg, Knoxville.
The tow bars that slide into the receiver on the coach will not allow the towing of vehicles with a high or low tow bar position because those types of tow bars are not height adjustable.
Both of my vehicles have the toad mounted tow bars.
Jack Gregg (Jackinkc)
Posted on Monday, May 02, 2005 - 5:21 pm:
You need a "drop hitch."
Dug
Posted on Monday, May 02, 2005 - 5:30 pm:
JB- The durango is higher than the bus.
Jack- Yeah, I've been looking at a 10" drop from blue ox.
Dug
John Jewett (Jayjay)
Posted on Monday, May 02, 2005 - 10:05 pm:
Northern Tool, Camping World, and most RV Sales have "dropped/Raised" recievers. About $25.00 Cheers...JJ
Geoff (Geoff)
Posted on Monday, May 02, 2005 - 10:06 pm:
Blue Ox 10" drop receiver, part #BX88132. I only had to get a 4" drop, works fine. What is your question? You want the tow bar as level as possible.
--Geoff
'82 RTS CA
Posted on Tuesday, May 03, 2005 - 10:34 am:
I would suggest getting the heaviest rated drop hitch you can find. A 10" drop will put a tremendous amount of leverage on the receiver. Also need a very beefy receiver. I believe they are available in 12,000# rating.
Stephen Fessenden (Sffess)
Posted on Thursday, May 05, 2005 - 9:53 pm:
There are aluminum hitches with a 12,000 lb rating and a 7 inch drop/rise. I have one. The aluminum unit is acutually stronger than the steel ones.
