Sojourner (Jjimage)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 13, 2005 - 8:27 pm: | |
While searching something else, came across this “air straighten-er” attachment now available for DD 60 series & others. It’s called “Tag” mean Turbo Air Guide It straightens incoming turbulent rotating (gravitational spinning) air just before turbo’s compressor wheel. Whenever we see water flowing into tub’s drain, gravity of earth rotating cause it to spin counterclockwise in the northern hemisphere & the closer to equator the faster it spins. Another example of already gravitational spinning water as compare to golf ball in place of water…golf ball still not enter drain hole until it stop gravitational spinning. Or during gambling, a “dice” gravitational spinning around until slow enough to drop into slot. A smooth funnel without screen will do same using water or any liquid. However you will notice it harder or unable to gravitational affect of water due to multi-divided drain’s holes or slots in kitchen’s sink with small index hole for bleeding water under raised drain basket So air react same as any flexible substance with weight or gravity affect. http://www.dieselpowerproducts.com/tag Someone might be interested to try TAG system. If you are in near north pole such as Alaska, may not be worth it. FWIW Sojourn for Christ, Jerry |
