Repower with 6v92 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » May 2005 » Repower with 6v92 « Previous Next »
dave4106
Posted on Sunday, May 22, 2005 - 2:12 am:
anybody know if a 6v92ta with a 15 degree tilt out of an rts2 will fit in a 4106?
Posted on Sunday, May 22, 2005 - 6:05 am:
If your going to use Transit Scrap , why bother with an Antique engine ?
The same bucks will get a DD Series 50 or Cummins or??
A modern 4 stroke will push the milage to 12 or more , although all transit scrap comes with fuel waisting slushpumps.Some are 5 speed tho.
You can use (modified) the entire cradle , rear axle with huge brakes and front spindles with sharp cut angle and those big transit brakes too!P/S if you need it for free (if you plumb it up).
This will bring the Sportscar of Coaches up another 45 years mechanically , and end the worry of 2 strokes eventually being outlawed by the smog Police.
Geoff (Geoff)
Posted on Sunday, May 22, 2005 - 6:24 am:
The RTS engine will not work in the 4106 unless it is modified to the 45 degree tilt you need. This is not worth the trouble-- there are several other transits that have the tilt you need.
--Geoff
'82 RTS CA
ned sanders (Uncle_ned)
Posted on Monday, May 23, 2005 - 8:25 am:
my 04 has the 6v92 set at the 15 degree level. the only trouble is it is hard to get to the back head.
ned sanders
huggy bear den
dave4106
Posted on Monday, May 23, 2005 - 12:56 pm:
alright ned sanders, i was giving up hope that anybody had done it. i need to pick your brain on what was involved in the installation. please email me @bluemountaintruck
ing@hotmail.com thanks dave
kelly thompson (Littlelover)
Posted on Monday, May 23, 2005 - 10:30 pm:
anyone know what intercity transit makes and models have series 50 detroit engines with the power reverser compatible with gmc hiway buses i have a 4107 am interested in repowering with something better also would like to know any available sources thanks mutch
Mike (Busone)
Posted on Monday, May 23, 2005 - 11:19 pm:
Here are some series 50 engines on esurplus. I know nothing about them. I see them on occasion on this site.
http://www.publicsurplus.com/IANAuction?ianac=cat&catid=402
