Air blowing back through ICC valve Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » May 2005 » Air blowing back through ICC valve « Previous Next »
JAMES R. RINK (Fakeguy)
Posted on Sunday, May 29, 2005 - 8:51 am:
Air leaking through exahust of ICC valve on my PD4106 . have replaced valve but apparently is somewhere else since contnues to leak EXCEPT when i apply the application (foot brake) pedal. think it might be the check valve. can operate bus fine...holds 110 psi, but leaks off soon after shut down...any clues,
thanks, nuts
Posted on Sunday, May 29, 2005 - 9:23 am:
Hello James.
Which style of parking brake does your coach have?
Spring or DD3?
Does the valve leak both with the parking brake applied and released?
Posted on Monday, May 30, 2005 - 5:22 am:
His coach probably has the Johnson bar as most 06 do.
Yes cleaning the valve (inversion valve?) that allows the air to get from the ICC circuit to the rear brakes should do it.
Posted on Monday, May 30, 2005 - 8:21 pm:
it has the manual hand brake (spring)...yes...leaks with applied and not..hey thanks, guys...i thought it was the inversion valve and appears that it is not too hard to get to from the side compartment under drivers window...may have to pull aux air tank to get to.
thanks again, nuts
