4104 shifting problem solved Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2001 » September 2001 » 4104 shifting problem solved « Previous Next »
bob m (64.12.102.38)
Posted on Saturday, September 15, 2001 - 6:33 pm:
the shifting rod on my 4104 snapped just above the differential. the shifting rod is not a rod but is thin walled tubing the protective covering had a worn spot that allowed moisture in and caused corrosion and it snapped clean.
Jim Wilke (152.163.197.209)
Posted on Saturday, September 15, 2001 - 7:42 pm:
Ah-so! But... how did you repair it?
Jim-Bob
bob m (205.188.197.59)
Posted on Saturday, September 15, 2001 - 11:21 pm:
the inside diameter is 3/8 so i put in 6 inches of 3/8 threaded rod 3" in either side with epoxy I also epoxied a sleeve on the outside. i hope it lasts???
