Buddy T
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 01, 2005 - 12:39 am: | |
Have a 1980 Eagle. At some point, can't remember how far back, we saw a post that gave very detailed instructions (measurements, etc) on the proper way to convert a two piece to a one piece door. Can anyone direct me to that, possilby in the Archives, but have searched and are either overlooking it, or it was somewhere else. Have the original converter that is located under drivers compartment. Have put a voltmeter on it, and it is operable. Wanting to put in some new interior lighting and want to use 12V so can run it off coach batteries while in transit, and will run a line to the converter from the genset to power the converter while parked. Would like to be able to use the same switch for both applications. Do I need to install some type of switching device to convert the power source to the switch from bus batteries to the genset/converter? |
