KEN M
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 17, 2005 - 11:36 am: | |
where can i buy smooth side panels, and what lengh and heigth do they come in, thanks ken 84XL |
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 17, 2005 - 11:43 am: | |
sheet metal shop...they will cut to whatever size you want |
Artis
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 17, 2005 - 12:26 pm: | |
R & M fiberglass |
James Maxwell (Jmaxwell)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 17, 2005 - 12:58 pm: | |
R&M fiberglass or a metal roofing supplier. Most sheet metal shops do not deal in anything longer than 10'. So, if u want a seamless sidewall in metal, you will likely not find it at your local sheet metal shop. A metal roof manufacturer has continuous sheet up to abt. 48" wide which they use to roll into raised rib roofing. Comes in guages from 16-28. Two 15'x48" 20 guage cost me $120, 3 yrs. ago. |
John Jewett (Jayjay)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 17, 2005 - 10:41 pm: | |
Check the BNO Archives for wide/long/smooth siding, since previously there were suppliers listed (St. Louis?) for 6 ft. wide 40 ft. long FRP panels. Good Luck. Alexander Aeroplane (.com)has aluminum sheets and rolls in extraordinary sizes. G'Luck...JJ |
Ricrhad Jones
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 18, 2005 - 12:14 am: | |
Check with Kemlite for RFP in widths to 102" and lengths to over 800' Richard Jones Castle Rock, WA |
Tim Strommen (Tim_strommen)
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 20, 2005 - 3:20 pm: | |
Try Metal Supermarkets, they are the source I'm using for my conversion. No rolls of steel/aluminum, but very large sheet sizes. If you use sheetmetal, preheat the metal to ~250 degF, before mounting it. This will help if you weld by reducing heat stress fractures, and if you rivet by preventing "oil-canning" (ripples in the metal on hot days). You can usually rent an oil-fired heater to do this. Cheers! Tim |
