Bus heat zone valves Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » July 2005 » Bus heat zone valves « Previous Next »
L Clinton
Posted on Tuesday, July 19, 2005 - 3:14 pm:
I have looked in the archives on this much beaten up subject. Has anyone found a reasonably priced 3/4" 12 V DC zone valve? ASCO makes a dandy for $165 ea N/C and $255 ea N/O. I'm trying to get a better deal.
Thanks
Larry
Craig (Ceieio)
Posted on Tuesday, July 19, 2005 - 4:49 pm:
Damn, at that price I better order a six pack of valves just in case I ever figure out what one of those things does! :-)
Craig - MC7; currently solar self-heating to 100F. Sometimes the rain stops in Oregon.
Jerry Liebler (Jerry_liebler)
Posted on Tuesday, July 19, 2005 - 6:45 pm:
Larry,
It's much easier to find 120 vac zone valves. I'm using a three way Honeywell valve to allow my water heater to run, both on the engine heat and Webasto, and bypass the fan heat exchangers in the summer. This valve is hooked to a "summer/winter" switch. I chose this particular valve because it draws no power unless it is moving from one position to the other. I figured that I don't want hot water going through all those heat exchangers when I'm trying to cool the bus in the summer. In the winter I'll control the fans to implement my 2 zones of heating + the water heater.
Regards
Jerry 4107 1120
