Weight of 6-71 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » August 2005 » Weight of 6-71 « Previous Next »
Bob Helm
Posted on Monday, August 08, 2005 - 2:54 am:
I need to pick up a 6-71 for ol' Bess and trying to decide what trailer to use. I have a tandem axel w/mobile home tires or a single axel with standard tires. Does anyone know the weight of the engine without the tranny?
Thanks, Bob Helm
Posted on Monday, August 08, 2005 - 10:05 am:
An 8V71 is 2,345 lbs. dry, so that's a ballpark for the 6v71?
mel 4104
Posted on Monday, August 08, 2005 - 10:37 am:
depending on what is still hanging on it such as flywheel, clutch, starter, bellhousing,alt.,manifolds, and such makes a differance so i would use the heavy trailer as it will not only carry the engine weight better but it is better to have too heavy a trailer than i light one that may blow the tires and cause an accedent. better to be safe than sorry.
Brian Brown (Blue_velvet)
Posted on Monday, August 08, 2005 - 11:57 am:
I'm with Mel. The tandems handle better on the highway, too.
Some engine weight info here: http://www.arsco.com/catalog/pg4detroitdiesel.htm
BB
Don/TX
Posted on Monday, August 08, 2005 - 1:34 pm:
Be sure to take along lots of tiedown and blocking supplies. I hauled mine home on a tandam axle trailer, the biggest challenge was getting the darned thing resting on something or the other and not sliding around on the trailer.
Jim Bob
Posted on Monday, August 08, 2005 - 2:35 pm:
I agree with them. The engine is not less than 2,000#. It wouuld be squirrelly on a single axle. Better too if the big trailer has brakes. As Don says, it will be a bugger to support & tie down. Pray it comes on the cradle!
Jim Stacy
Posted on Monday, August 08, 2005 - 10:01 pm:
Old unmounted tires are great cushions for heavy, odd shaped items. (Are those the same mobile home tires marked "illegal to use on other than a mobile home?) Sure are a lot of those around. Good luck.
Jim Stacy
Posted on Tuesday, August 09, 2005 - 9:45 am:
"illegal to use on other than a mobile home"
Does anyone know for sure where this comes from, and who might be an inspector checking for this?
I checked with the mobile home dealer across the street from me and they do not know anything about who declares them illegal.
I own one three axle trailer that uses these type rims and I get like new replacements, with rims, for $50.
Posted on Tuesday, August 09, 2005 - 11:38 am:
Richard - In the State of Florida, the axles and running gear are meant, after each use, to be inspected and/or rebuilt - prior to the requirement for the newer 12 ply tires the older style tires were not for use more than a certain number of trips or total miles - if you have the newer 12 ply they are ok up to the normal tread requirements - enforcement in Fla can be done by DOT , DMV , or any law enforcement agency -
BTW - I would not use donuts on any trailer of mine - for a myriad of reasons -
Niles
