warren wenzel
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 11, 2005 - 12:34 am: | |
Can I pull the axels out by the wheels? Do I need a puller for the axel cover? How much does the pumpkin weigh? Anyone know of a company in San Diego who can "set" it up? I have the tools, just need the directions. Also some gears- ratio is 3.55 model 155OX |
RJL
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 11, 2005 - 1:05 am: | |
Make and model of bus would be helpful. . . Yes, you can pull the axles out by the wheels. Shouldn't need a puller for the axle cover, unbolt. May have to persuade it with a hammer, etc. Pumpkin weighs between 150-300 lbs. HTH |
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 11, 2005 - 1:20 am: | |
Depends on what you have, but certain axles have a couple of threaded holes to put the cover bolts in to "push" the axles out. also you probably need that bus over a pit and use a transmission jack to handle the weight of the pumpkin. those things are very heavy, some up to 1000lbs and dangerous to try to do on a floor or driveway. we do ours over a pit and they are still hard to manage. |
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 11, 2005 - 6:12 am: | |
try to find a complete pumkin out of a wrecked/junked bus or truck,wash out the banjo before inst. |
gusc
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 12, 2005 - 5:39 pm: | |
warren, Did you rec my email about HB Industries? |
