Anybody rebuild a turbo for a 6v92? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » August 2005 » Anybody rebuild a turbo for a 6v92? « Previous Next »
james dean boggs (Jd_boggs)
Posted on Friday, August 19, 2005 - 4:34 pm:
I have some oil leakage from the turbo and want to know if rebuiling the turbo is a difficult task? Or cheaper to buy one already rebuilt? Ebay has one for about $550.
jimmci9 #2
Posted on Friday, August 19, 2005 - 6:47 pm:
our shop rebuilds turbos....and i'm the 1 that does it.... you must be able to measure the shaft, bushings, and housing very accurately... rebuild kits are cheap.....we send the turbine wheel, shaft and compressor wheel out for rebalancing prior to a rebuild...other than that, only a special pair of snapring pliers is necessary.... and be really clean....
Posted on Friday, August 19, 2005 - 7:55 pm:
Jimmci9,
Do you use a ultrasonic cleaner to get the housings "clean enough" or ???
Who does your rebalancing?
jimmci9 #2
Posted on Friday, August 19, 2005 - 9:59 pm:
i bead blast the hot section.... and change the nozzle if necessary...glass bead blast the cold section.... run the center section thru out hot vat....parts dept ships the turbine and compressor wheel off somewhere for balancing....it takes about a week for it to come back.... we're an engine rebuild shop...the cat engines i rebuild take about 350 man-hours to rebuild... so waiting a week isn't a problem....
Pat Bartlett (Muddog16)
Posted on Saturday, August 20, 2005 - 5:52 am:
Jimmci9, Can I ask where you are located?.....Pat
