John Mimidis (Cjm)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 25, 2005 - 11:54 pm: | |
I have a 9.5kw Next Gen Kubota diesel generator with a Stamford head. Doing the math, it should produce about 40amps. What size circuit breaker should I put on it? I want to protect the head but also avoid nuisance tripping. Thanks in advance, John |
Bob Vandawalker (Rav221)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 26, 2005 - 5:27 am: | |
40amp at what voltage? If your talking 120V, a 9.5kw generator should produce double that figure. So I take it for granted your talking 240. We used a main breaker slightly less than rated capacity. You should be able to find specs for your generator on-line. Need to know if you are wiring into a 120 or 240v system and also the capability of your generator. |
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 26, 2005 - 8:01 am: | |
John, see my response on the other board you posted on. Richard |
John Mimidis (Cjm)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 26, 2005 - 3:46 pm: | |
Thanks, Richard. John |
