Baggage bay doors construction ? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » August 2005 » Baggage bay doors construction ? « Previous Next »
pipes
Posted on Tuesday, August 30, 2005 - 12:49 am:
Hi Gang ! I am about ready to tackle the job of constructing the baggage bay CAFE style doors, I think it's called.
Would like info on, hinges, frame,locks ETC. I have an 05 Eagle and have/will be using 1/8 inch marine grade (Semper Fi) aluminum for the skin ...Thanks in advance Ken.
Mike SS
Posted on Tuesday, August 30, 2005 - 2:23 pm:
Hi Ken, I have 05 Eagle also. We (JJ) built a 1" x 1" box frame (steel) and skined with 20ga paint lock, welded the corners. Then we used 1" SS piano hinges pop-rivet to frame. The normaly closed door is held in place by top and bottom spring latchs and normal RV round lock and tab for the other door. Add weather stripping inside
and astrical on back of center.
Mike
Ps JJ I'm back from CR for 1 month :-)
John Jewett (Jayjay)
Posted on Wednesday, August 31, 2005 - 10:34 pm:
Hi Mike, What are you doing back in Costa Rica? Find me an LBFM, and I'll be down. Is "C" with you, and BTW, where's the Eagle? Still locked up? Cheers...JJ
