V730 capacity Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » October 2005 » V730 capacity « Previous Next »
Johnny
Posted on Monday, October 10, 2005 - 8:48 pm:
How much ATF is needed to refill a V730 in a TDH5300 with a 6V71N for a fluid change?
Posted on Monday, October 10, 2005 - 10:41 pm:
According to the book, 34qts are are required after draining and 36qts after overhaul.
Hope that helps.
Dale
Brian Brown (Blue_velvet)
Posted on Tuesday, October 11, 2005 - 2:02 am:
You probably know this, but you can alternatively use motor oil in these... C-4 spec. i.e. 30wt. Rotella, Delo, etc.
Posted on Tuesday, October 11, 2005 - 7:55 pm:
Brian, That's what alot of the techs recommend. The clark transmission guys recommend it also. They tell me that the the pins and gears last longer with engine oil. I believe the next fluid change I am going to change to 30wt. engine oil.
Dale
