Help with bus skin Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » October 2005 » Help with bus skin « Previous Next »
Camill Paul Elbisser (Paul)
Posted on Monday, October 10, 2005 - 10:05 pm:
I do not know to use Aluminum or paint grip galvanize steel?
Is the .063 6061 aluminum mill finish the right type to use?
G60 the right number for paint grip galvanize steel at .020
and the type of rivet to use on each
We are now sand blasting and painting all the the new and old steel from the roof raise.
I have 25% of the job done.
Must order some thing soon.
Rich International Bus & Parts
Posted on Tuesday, October 11, 2005 - 1:54 pm:
Use the same material in your rivets as the skin you are riveting (eg: SST skins use SST rivets, aluminum skins use aluminum rivets). If you use dissimilar metals, you will learn a lot about electrolysis, in a BAD way...........Electrolysis is the negative, corrosive, reaction between dissimilar metals. Induced & amplified by electricity (Batteries).
I usually tell people to NOT use a corrosive metal on a bus (Steel, galvanized, etc..). I have heard the stories of a $10,000 paint job that is "bubbling up" with corrosion just a few years after getting the paint job done.
Stainless steel & aluminum do hold up better, with less prep worries. Sika Flex is also instrumental in minimizing electrolysis.
Rich
800-468-5287
