Kevin Wood
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 17, 2005 - 2:44 pm: | |
I have an MC9 with the 8v71. I see 15-40wt oil for sale everywhere, but my manual states use 40wt. Is it a problem to use the more common oil or should I search harder for straight 40wt? Thanks, Kevin |
David Dulmage (Daved)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 17, 2005 - 3:37 pm: | |
Single weight only, API CF-2, meeting Detroit Diesel specs. Multi-grade oil is not suitable for an 8V-71. Excessive oil consumption will result from using multi-grade oil , with possible premature engine failure. Dave D |
J.C.B. (Eagle)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 17, 2005 - 3:47 pm: | |
Try NAPA they can order the 40wt oil for you. I use Rotella-T 40wt and they have always ordered it for me. |
JR
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 17, 2005 - 4:37 pm: | |
Two popular correct DD 2 stroke oils are Rotella 40wt (NOT 15W40 which is everywhere), and Delo 100. DD recommends using 40wt oil as long as you can start the coach. Most folk don't use a coach when the weather's so cold that you cannot start a DD when the block heater is used. The oil may have to be ordered. I get Rotella by asking for it from the distributor. Due to a miscommunication with the distributor, and the fact that a case has 6 gallons and not 4, I've got a lifetime supply of Rotella 40...11 cases still. May be a benefit now with all with the recent price increases...I got free freight too. Don't put multi-viscosity oil in your 2 stroke...or as DaveD says, you'll be engine shopping. |
Kevin Wood
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 17, 2005 - 10:04 pm: | |
Thanks for the info. I will source out the straight 40wt. Kevin |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 17, 2005 - 10:18 pm: | |
Who has the link to the DD report on oils for Kevin to read? happy coaching! buswarrior |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 17, 2005 - 11:07 pm: | |
http://www.detroitdiesel.com/public/technicianguides/technav.asp |
