15KW gen problems Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » November 2005 » 15KW gen problems « Previous Next »
Wayne Buttress (Eagleman)
Posted on Thursday, November 03, 2005 - 3:38 pm:
A friend has a 15kw Yanmar generator connected to an invertor that is connected to a bank of batts. that supply his house with 110v.
The generator will run finefor 10 min, or so and then it starts chugging (like missing) for a few mins. and then run ok. This problem is intermittant.
Any clues would be appreciated.
Thanks, Wayne
JimH
Posted on Thursday, November 03, 2005 - 4:35 pm:
Try checking ALL the fuel filters. Give a Yanmar fuel and clean air and they run forever. Sounds like a fuel or fuel delivery problem. If filters are clean, check fuel lines and fuel pumps.
David Hartley (Drdave)
Posted on Thursday, November 03, 2005 - 9:10 pm:
Probably a small air leak on the fuel line. the engine will chug and lug until the air bubbles pass through the injector return lines.
Make sure all the fuel line clamps are nice and tight. I like to put double clamps on when I have them and happen to think about it, saves on that seeping air bubble getting in.
