Ddec 2 60 series Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » November 2005 » Ddec 2 60 series « Previous Next »
keith d dyson
Posted on Tuesday, November 15, 2005 - 3:45 pm:
can any one please help ive got a mid 31 :sid 26 fault and i need to trace the fault can any one give me some directions where to look .i cleared this fault once and stayed off for a couple of hours but now its returned thanks in advance keith d dyson
Jim Shepherd (Rv_safetyman)
Posted on Tuesday, November 15, 2005 - 4:56 pm:
Hi Keith. I hope somebody more knowledgeable than me chimes in here.
The MID identifies the microprocessor involved. The engine is typically MID 128, so I am not sure what MID 31 is and my Pro Link information does not list it.
Could it be MID 130 in which case it would be a transmission. If that is the case, SID is a “C6 Clutch Pressure indicator”.
Jim
Bill Gerrie
Posted on Wednesday, November 16, 2005 - 10:25 am:
Keith
The only info I can find for SID 26 is as follows
SID 26 - aux output #1 short to battery (+) - F3
SID 26 - aux output #1 open circut - F3
SID 26 - aux output #1 mechanical system not responding properly - F3
As you can see they all say pin F3. Hope you can use the info and find the problem. Bill
Posted on Wednesday, November 16, 2005 - 7:36 pm:
code 26 - Power control switch - indicates that the "user defined / power control switch" has been used ---- do you have a circuit on pin H2 (524) - this would indicate that you have a "user defined" device that let the h2 line go to ground - this tells the DDEC to turn on the "stop engine" and the "check engine" and begins "power down" and shutdown processes
code 31 - indicates ecu detected the following fault for over 2 seconds
A-open in "check engine" or "stop engine" light circuits
B-short to ground in the "check engine" or Stop engine" or "cruise active" or "crank position sensor" or "engine brake sensor" circuits or any of the 3 "aux drive circuit
hmmm 31 could mean you have no bulbs in the stop or check engine lites or have not wired the circuits yet - or the to high wattage bulbs (looks like a short)
clears as mud ?? call 386***672***0571
Posted on Wednesday, November 16, 2005 - 7:41 pm:
Bill, I found the same information, but that is for MID 128 which is the engine. Also, it did not make much sense for a bus.
Kieth says that his MID is 31 which would have a different series of SIDs. I just can't find any listing for MID 31. In a bus, it should only show an engine MID of 128 or a transmission MID of 130. If it were a newer bus, an MID for ABS brakes might fit.
Bottom line, we need to find out what processor the MID 31 addresses.
Jim
Bill Gerrie
Posted on Thursday, November 17, 2005 - 9:07 am:
Jim
You are right. You are more knowledgeable then I am on these engines but I couldn't find MID 31 either and figured what ever he is using has to be similar to the MID 128 we are all used to. I figured it might be somewhere to start. Bill
