Sean Mormelo (Sventvkg)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, November 17, 2005 - 11:36 pm: | |
My bus is still basically a shell with factory insulation and it's going down to 21 degrees tonight! I'm at the Asheville, NC KOA west and have a propane heater and 2 electics humming in the bus. They're keeping it pretty comfortable though. |
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 18, 2005 - 6:00 am: | |
If that propane heater is not outside vented , be sure to ventilate the coach as soon as you can. Water Vapor is the result of burning propane , and it will condense behind the insulation on the cooler outside walls. FAST FRED |
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 18, 2005 - 9:20 pm: | |
Thanks Fred! I'm paranoid using this little propane heater as it is. I keep a window cracked as it is. |
