chris
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 21, 2005 - 3:48 pm: | |
i got an estimate today to sodablest my coach. they get $150.00 per hour from setup to dismantle. i estimate a days work. they said 4-5 hours. anyone have knowledge of this procedure? i think its a great price considering i would be sanding for days. your thoughts chris |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 21, 2005 - 4:01 pm: | |
__. Do you mean as preparation for painting? __. When Central Carolina did my bus the summer, they used chemicals to strip the old paint. I have an aluminum panel body and everyone said that any kind of blasting will stretch the aluminum and cause it to "sag". I'm very pleased with the result. YMMV, BH, NC USA |
Ed (Ednj)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 21, 2005 - 6:00 pm: | |
Chris That sounds like a fair price. The soda is easy clean up and wont hurt rubber or glass. the new thing out there is dry ice blasting that even cleaner |
chris
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 21, 2005 - 8:07 pm: | |
bruce yes thats for paint preperation now to find a painter thanx chris |
Jim Stacy
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 21, 2005 - 9:16 pm: | |
Chris, Schedule the painting for IMMEDIATELY after the soda blast. Soda blast is a great process, but the metals are left with NO protective coating. Oxidation will occur immediately (within hours,including aluminum). Jim Stacy |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 21, 2005 - 10:35 pm: | |
__. Chris, are you out there in the People's Republic like everyone else????? |
chris
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 22, 2005 - 7:29 am: | |
boston ma chris |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 22, 2005 - 9:59 am: | |
Soda blasting is not as abrasive as sand and is much preferred by most paint shops over sand or chemical stripping. Sand will heat the surface and high pressure can damage the panels as well as etch glass and other materials. Sand tends to always stick around and get in the finish coat also, as well as chemical strippers get under rivets or in seams and then a few weeks later destroys the paint job. The soda is easily washed off and it does a great job. Next down the line is I believe Walnut hulls if they are available. Richard |
DAVID HEAD (Chuck)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 22, 2005 - 9:13 pm: | |
Best possible method to remove paint without damage to any of the other parts as for oxidation of the panels use an acid etching primer best for non ferrous metals such as aluminum and stainless |
