Disolving foam insulation Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » December 2005 » Disolving foam insulation « Previous Next »
Ray Lala (Rayshound)
Posted on Thursday, December 08, 2005 - 11:15 pm:
I removed floor in mci-8, removed plywood in a/c floor duct. I want to weld unistrut in air duct to run conduits & webasto copper tubing before laying down 3/4" plywood. In this floor duct close to the front stairs under the removed 1/4" plywood duct bottom is around three foot long of spray foam more than likely used as a seal. Does anyone know how to disolve this foam? With out hurting all the copper airlines? I will have it refoamed. Thanks Ray
Doug Wotring
Posted on Thursday, December 08, 2005 - 11:41 pm:
Acetone
Mike (Busone)
Posted on Thursday, December 08, 2005 - 11:47 pm:
Good luck that stuff is nearly indestructible. It is for the most part solvent proof. Acetone will work will work while the foam is fresh. After it has dried you are out of luck. Pulling it out by hand is the only way I know of.
