J. J. (208.161.144.11)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 30, 2001 - 2:08 pm: | |
good day. since i've never examined one all that closely, on an MC-9, street side, what lurks behind the panel between the HVAC grill door and the forward- most baggage door? a coach i saw pictures of had the h2o inlet located in this panel. wondering how the guy kept line from freezing. thanks and good travels. |
Jerry H. (Coachconversion) (65.2.65.246)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 30, 2001 - 8:24 pm: | |
JJ: Attached to the mesh door is the condenser coil. In between that cavity and the first baggage bay is the air cond. air filter, central heat blower motor, blower housing and central heat core. There's a plywood access panel from the baggage bay for service. I assume the h2o inlet went into this hvac cavity and [maybe] 90-d into the first bay? He could have insulated the bays really well and provided a bit of heat to keep from freezing. Unusual as (I believe) many converters choose to use the rear bays for fresh water and waste tanks, water heaters, etc. As Scott would say ... just my $0.02 worth. Hope you don't mind me borrowing that one Scott :-) Jerry |
Scott Whitney (63.151.69.220)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 30, 2001 - 9:20 pm: | |
N'worries! : ^ ) Scott |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 30, 2001 - 9:43 pm: | |
Hey Scott. Can you email me your email address? Email addresses posted on MAK don't work. I want to pick your brain. Thanks, Jerry jerry@coachconversion.com |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 30, 2001 - 10:18 pm: | |
Hi Jerry, Sure an e-mail to you is on the way. Mine is: info@ancient-wisdom.com I usually insert some nonsense in the middle of my address in all caps like NOSPAM or SPAMBEGONE or SPAMAWAY that has to be manually deleted by a human. That prevents the spam robots (software programs that crawl the web) from scavenging my real e-mail address off of BBs . . . Scott |
J. J. (208.161.144.10)
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 31, 2001 - 9:02 am: | |
thanks for the info guys. J.J. |
