Voltage on a 19667 GMC Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2001 » November 2001 » Voltage on a 19667 GMC « Previous Next »
Chavel Silva (205.188.192.21)
Posted on Friday, November 09, 2001 - 10:31 pm:
I was hopeing someone could help me as to the voltage on my 1967 GMC OmniBus. It has two very large batteries that are tied together. I'm more than sure that they are 12volt batteries. Do I multiply 2 x 12? Thanks in advance.
RJ Long (24.127.8.58)
Posted on Friday, November 09, 2001 - 10:48 pm:
Chavel -
If you can provide us with the VIN on your coach, we'll be able to give you a more intelligent answer.
Look on your vehicle registration for the VIN, it most likely will start with either a P, S, or T.
RJ
Scott Whitney (63.151.69.220)
Posted on Friday, November 09, 2001 - 10:59 pm:
See info related to your question posted under heading:
"Starter change 4106"
Scott
Doug (Toolman) (207.44.55.121)
Posted on Saturday, November 10, 2001 - 12:06 am:
Chavel,
If the bat's are connected "+ to -" then the system is 24v. If the bat's are connected "+ to + and - to -" then it is a 12 v system.
Hope this helps,
Toolman
