Sojourner (Jjimage)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 18, 2006 - 2:59 pm: | |
Electrical Load Evaluation is a great link to bookmark. http://www.absak.com/design/load.html At bottom of page a link to load calculation form in pdf file. Remember to multiply AC appliance’s wattage time’s 1.15 equal inverter loss wattage. At bottom/right of form is total wattage that including load correction factor And have "Power Consumption Table" FWIW Sojourn for Christ, Jerry |
morgan Clough (Mclough777)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 18, 2006 - 11:29 pm: | |
ok, i plugged in the numbers and i figure i need about 2400 watts a day. how does that equate in to amp hours? |
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 19, 2006 - 1:06 am: | |
Morgan Volts x Amps = Watts at 12V = 200 AH x 1.15 (inverter) = 230AH at 24V = 100 AH x 1.15 (inverter) = 115 AH Avoiding depletion of greater than 50% (best for battery life) bank must be twice the AH capacity between charging events. |
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 19, 2006 - 11:22 pm: | |
Morgan, to answer your question, if you have 12 volts, you should have 4,800 watt hours of capacity, which means 400 amp hours. That would require 4 golf cart batteries. If you have 24 volts, the same 4 golf cart batteries in a different configuration would be needed. Golf cart batteries are 1.3 kwh of capacity per, which means that you really should only use about 1/2 kwh per between charges. For what it's worth. Tom Caffrey PD4106-2576 Suncatcher Ketchikan, Alaska |
