Matt (Hgtech)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 25, 2006 - 12:15 am: | |
Where is the best place to add a shop air hookup on a Model 05 Eagle. |
Brent Coursey
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 25, 2006 - 4:54 pm: | |
I just saw in my Eagle Driver's Manual where it said that there is an air connection behind the Eagle emblem on the front of the bus. I think it was put there to able a tow truck to hookup and utilize the air brakes on the bus. I'm a newbie so I'm just throwing out info that someone else will probably explain further. Brent |
Tim Jones (Torquester)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 25, 2006 - 10:23 pm: | |
Matt, If you have an air drier on you bus you should add air to the bus system between the bus air compressor and the inlet to the drier. This will insure that the air that you add to the system will be sent through the drier media. This will allow you to be certain that the air is is clean and dry as it enters the system. hth, Tq |
