A 'comfortable dinette booth? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » March 2006 » A 'comfortable dinette booth? « Previous Next »
Jerry Liebler (Jerry_liebler)
Posted on Monday, February 27, 2006 - 1:24 pm:
I'm about to build a dinette booth and searched the archives for hints. I found a FF post that showed a seat contour with 4 different angles but I can't see how it'll make into a bed less than 8 feet long. I'd like better comfort than the typical 2 cushion set up and don't want a bed longer than an extra long twin (80"). I've measured the most comfortable chair in my house and think it can be duplicated with a 3 cushion design with a 16 " seat cushion tilted 16 degrees, an 18" back cushion 22 degrees off of vertical and a 6" vertical headrest. If I used 3" cushions I'd have a 28" table. With 2 hinges per side I can arrange for the seating angles and have it 'fold' flat for a bed. So what are the questions? Can 3" cushions work for both seating and sleeping? If so what ILD foam will be needed? If I went to the more usual 5" cushion I'd lose storage space and the table would shrink to 24", again what Ild is best? Is a 24" table too small? With the 3" cushions I could add an air mattress, is that the best answer? Has anyone built such a contraption?
Regards
Jerry 4107 1120
Ed Jewett (Kristinsgrandpa)
Posted on Monday, February 27, 2006 - 7:16 pm:
I believe I'd hit the motorhome sales lots and look at what they have till I found one I liked, then measure it.
If you come up with a good design I'd like to know since I have yet to do mine.
ED
motorcoach1
Posted on Monday, February 27, 2006 - 7:19 pm:
would a fold out drop leaf table help in your need ?
TVDAD
Posted on Monday, February 27, 2006 - 7:26 pm:
I found a railroad salvage company called the Hobo railway and bought whats called a walk overseat and built a table between them. The advantage of the walk over seat is that it also makes a love seat faces into the living area.
Mark Scott
Posted on Monday, February 27, 2006 - 8:28 pm:
Jerry, I'd look at the Villa Furniture website. On it, you will find a dinette in section view with a few dimensions on it. I built an L shaped dinette with a table that slides back and forth. Its comfortable, but not set up to sleep someone, not yet anyway. Do it your way, Mark
Posted on Tuesday, February 28, 2006 - 5:56 am:
The contoured design does work for sleeping , as youre head rests on a pillow so the seat dip necessary for fine sitting is not noticed.
As the unit will probably be used 99% of the time for sitting , be very wary of the 90Deg designs that are uncomfortable 100% of the time.
Remember resturants chose the 90deg backbreaker to get the tables to turn over, and get the next diner in, NOT for comfort.
There is a huge difference between the density of sitting foam and sleeping foam.
Simplest I have seen was a better quality air mattress blown up for the occasional guest and placed on the dinette for the evening.
Brent Coursey
Posted on Tuesday, February 28, 2006 - 9:56 pm:
Jerry,
I picked up a book today at the library called: "Cruising World's Workbench" author Bruce Bingham. In the book they have a bunch of projects to help boat people make the most of their on-board spaces. In the book they have a couple of pages that give some good ideas on dinettes/tables. You might want to check it out...literally!
Brent
Posted on Wednesday, March 01, 2006 - 12:00 am:
Brent,
Thank you for the hint, it'll be difficult for me to check it out as I live in rural Kentucky where libraries aren't high on the government's priorities.
Regards
Jerry 4107 1120
Gary Stadler (Boogiethecat)
Posted on Wednesday, March 01, 2006 - 12:47 am:
Used ones for $15 bucks...
http://www.amazon.com/gp/product/0071379630/002-8887486-3412811?v=glance&n=283155
Ed (Ednj)
Posted on Wednesday, March 01, 2006 - 8:55 pm:
Jerry
I sent you a picture.
Check your email
