FAST FRED (209.26.87.107)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 11, 2001 - 3:40 pm: | |
With so many boards I hate duplicate posts , but for the new folks this might be a help. There is ALWAYS some water in the best of fuel, and more gets added when you go thru a temp change , with out a full fuel tank. A drain would be great , as would a Navy style fuel tank that can easily be bailed of any water or crap. But this type tank is expensive to build so you won't see it on a "cheap" $500,000 motor home. The simplest way I know of being safe , is to purchase an oil change device for a boat. This is a large plastic pump/tank about 6 in diameter and 2 ft tall. Pumping puts the tank in suction and a flex tube is usually stuck into the dipstick hole . All you do is stick the pickup , with an extender if needed as close to the bottom of the tank as you can get. This will suck everything from the bottom of the tank , you can see what your lifting , as the unit is clear plastic. Worth doing every few years , the pumps are $50 or so , would be good for a club tool. IF you dont clean the tank , eventually you will get a load of fuel with "bugs" in it. The bactreia live on the interface between the fuel and water , and eat the fuel. This is no problem but the dead bugs and their waste products can easily clog fuel filters. FAST FRED |
Scott Whitney (63.151.69.220)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 11, 2001 - 9:16 pm: | |
Hi FF, That is good advice about fuel tanks, thanks. I also agree that multiple posts on the same or different BBs is a bit much. What seems to happen is that two disjointed conversations occur at the same time. Personally, since I browse several BBs a day, I don't like to take part in a conversation about the same question in more than one place at a time - as much as I like chatting about busses! Scott |
