12 volt entertainment systems on 24 v... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » March 2006 » 12 volt entertainment systems on 24 volt MC9 « Previous Next »
Dave Wilson
Posted on Monday, March 20, 2006 - 11:52 pm:
I installed 5 12 volt tvs 10inch and dvdcd combo and ran it of peg 50 witch is 12volt running of the same battery that the headlights run off but when ishut down i have same battery dead. What is the problem.
Posted on Tuesday, March 21, 2006 - 12:11 am:
Using the center tap isn't a good idea for getting the 12volt
supply, if that's what you're doing.
If you're tapping into the 12v supply for the headlights, you
may be tapping into either the resistor, or the 24 to 12 converter,
both of which are controlled by the on/off engine key. That
24 to 12 voltage converter was designed for the headlights, and
not much more.
The best thing to have, is a separate high amp 24 to 12 converter,
dedicated to the 12v system you want to power.
Optimally, it's best to have a 12v battery bank, dedicated
to the 12v "house" supply, and charged by it's own 12v
alternator, and/or 24v to 110vac inverter to a 12v charger..
Lot's of options, you just don't have the right one, yet...
Dave Wilson
Posted on Tuesday, March 21, 2006 - 12:20 am:
John mc9 Could i install a 24volt to 12volt invertor and use one of those empty pegs, and run everything of that peg.
Posted on Tuesday, March 21, 2006 - 12:33 am:
A 24 to 12 Converter should be run from the battery directly.
The draw would be too much for one of the "pegs" to supply.
You can then run the 12v to an empty unused peg, and wire
from there!
Iffn' youse don't have a manual, some charts are here:
http://www.dialup4less.com/~aabn/MC9_docs/
Dave Wilson
Posted on Tuesday, March 21, 2006 - 12:52 am:
John MC9 That is what i meant to say i will go ahead and do that I just recently took out the old systems and put in all new`but been having a few problems with the power. The nappa dealer in Yellowknife will bring in a couple of those for me. If i can be of any help let me now have lots` of good spares. Thanks Dave.
