3 stage regulators Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » March 2006 » 3 stage regulators « Previous Next »
Posted on Sunday, March 26, 2006 - 2:52 pm:
FF and others have mentioned using a good three stage voltage regulator on the large oil cooled coach alternators to properly charge the house batts. going down the road.Who makes these that work well? Thanks.
Dan C
Posted on Sunday, March 26, 2006 - 3:30 pm:
Try Xantrex
http://www.xantrex.com/web/id/107/p/1/pt/7/product.asp
It is also available in 24 volt
The user guide is at:
http://www.xantrex.com/web/id/594/docserve.asp
The data sheet is at:
http://www.xantrex.com/web/id/60/docserve.asp
Dan C
Posted on Monday, March 27, 2006 - 6:03 am:
Google "Ample Power" and "Balmar" , for other brands.
For a bus , be sure the field current can be 8A
and ESP if you have halogen headlamps , be sure to look for a nite running option , that reduces charge voltage.
David (Davidinwilmnc)
Posted on Monday, March 27, 2006 - 8:52 am:
The Xantrex regulators look nice. How would one use this to charge the house bank of batteries and the starting batteries? I know the two banks are of different capacity and type. Is there some way to automate charging the start batteries first then charge the house batteries? I suppose a relay could be installed with a manual switch to bridge the banks, but something automatic would be nice.
David
Posted on Monday, March 27, 2006 - 10:33 am:
True Deep Cycle batts, with their different construction and charge acceptance capacities benefit most from 3 stage charging. In fact, 3 stage is required to get best performance/economy from Deep cycles.
Start batts aren't so critical
Posted on Monday, March 27, 2006 - 11:37 am:
So all the batteries could be tied together? I assume this would slightly overcharge the starts, but I wouldn't think that would be as bad as not correctly charging the house set.
Posted on Monday, March 27, 2006 - 1:24 pm:
You'll use more water in the start batt(s) since they will be exposed to voltage levels above 13.8 (or so) longer than necessary as Deep Cycles take longer to "top off" and want to finish above 14VDC.
Brian Elfert
Posted on Monday, March 27, 2006 - 11:11 pm:
Xantrex makes a device called a Pathmaker that automatically opens when no voltage is present.
Basically, when no voltage is present from the alternator or other power source your house batteries will be disconnected. There is also an override to use the house batteries to help start the coach in an emergency.
Brian Elfert
Posted on Tuesday, March 28, 2006 - 6:05 am:
"I know the two banks are of different capacity and type."
TYPE?
If the starts are flodded and the house is AGM or somthing else with different charge voltage requirements , you need the controller.
If there all of the same TYPE construction a simple solenoid and one big bank while charging works fine.
The Deep Cycles will take a bit longer at higher charge voltage , but its nothing the Starts weren't designed for.
Worst case you add a bit of Extra water every month.
Hydrocaps work great! if youre lazy abput watering.
Posted on Tuesday, March 28, 2006 - 10:18 am:
FF, that sounds like what I wanted to hear. This should be an easy one, and simple is good. Thanks for the info guys.
