Casper4104
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 28, 2006 - 12:54 pm: | |
Hey guys, I’ve found a Speedo/odo setup with what looks like an inductive proximity sensor on the end of a nice long cable, including a mounting bracket for the sensor. I'm guessing it's one where you duct tape a magnet to a wheel or something. It’s an MCI part – part # 7L-8-736 . Would this work on my PD4104 with 12 volt negative ground electrical system? I have no speedo and no tach – and I’d really like to have one or the other. I was planning on just getting a GPS to use as a speedo, but this would be better. I hope it will work – I’d love to have a speedo that goes to 140 mph in a 4104! (LOLOL) Thanks, Casper4104 |
Frank71
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 28, 2006 - 1:11 pm: | |
drill 4 holes 90 deg apart and tap 1/4 20 and put in 4 bolts, mount the sensor a dime thickness from the bolts, the sensor will sence the bolt heads Frank Allen 4106 |
Larry & Lynne Dixon (Larry_d)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 28, 2006 - 1:15 pm: | |
Casper I can't be much help but my 4905 has an MCI speedo, only thing is I don't know what had to be done to make it work. I looks a little funny in the dash but it works very good. 4905 larry |
Casper4104
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 28, 2006 - 1:31 pm: | |
Wow, that was quick... Slow down there Frank, D&T 4 holes in what? A wheel?, the driveshaft? Thanks for trying, but I'm kinda dense. That's good news Larry - it can be done. Thanks. The big if is , will it work with my 12V electric? MCI's run 24V don't they? Thanks, Casper |
Luke Bonagura (Lukeatuscoach)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 28, 2006 - 1:55 pm: | |
Hi Casper & Folks: Casper, we stock the complete 12 volt speedo assy for your Negative Gorund PD4104. Hit on my name at the top of this post and E-Mail me your contact info. I Hope this HELPS!!!! Happy & SAFE!!! Bussin' to ALl. LUKE at US COACH |
Ron Walker (Prevost82)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 28, 2006 - 2:17 pm: | |
Casper D&T 4 holes on the edge of the brake drum. Ron |
Mike S.
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 28, 2006 - 8:16 pm: | |
Hi if it’s the one I think it is be aware , the BOLD white easy to see numbers are kilometers and the hard to see numbers are MPH. Could be confusing at a glance |
Frank 71
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 29, 2006 - 9:34 am: | |
Casper, sorry was trying to hurry and hurried a bit too much, the holes go in the outer edge of the brake drum, the censor then reads the speed as the bolts go by. i did my own Frank Allen 4106 |
Casper4104
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 29, 2006 - 9:48 am: | |
Great Frank, thanks. Was your 4106 12V or 24V? Was your speedo setup 12V or 24V? Does it matter? Thanks, Casper |
Frank 71
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 29, 2006 - 5:16 pm: | |
Casper, 12 v but it came out of a mci 9, dont know if it matters or not as i never had a 24 v system. Frank Allen 4106 |
