Mike Eades (Mike14905) (209.14.204.175)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, November 24, 2001 - 12:24 pm: | |
I am putting unit in my coach and I am looking for a good way to secure the doors while in motion. Any Ideas? Please help. Mike |
bobm (205.188.193.166)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, November 24, 2001 - 1:01 pm: | |
i used brass door slide latches to keep the doors closed while moving and also to keep them from closing when the unit is shut off. |
jjrbus (205.188.200.23)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, November 24, 2001 - 8:27 pm: | |
I copied what the RV's have an L shaped piece of stainless with a hole in it for pin bolted to the holes where you can switch door hinge from left to right between top and bottom door make a 2 diameter pin such as a bolt with rubber tubing half the length and drop it in the hole, will also keep doors from closing when stored. Work/Play safely Jim Robinson |
Dwight (63.16.168.244)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, November 24, 2001 - 8:39 pm: | |
Hi there at Lowes, child safety door locks with velcrow and double sided tape to hold it in place |
Bill Butler (63.15.111.187)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 30, 2001 - 4:22 pm: | |
BUNGEE!!! |
Glenn Isaacs (Paso) (209.179.216.221)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 30, 2001 - 9:09 pm: | |
marine door hooks |
Steve Fessenden (63.27.89.187)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, November 30, 2001 - 10:38 pm: | |
There is a plastic latch I saw on a rental house boat in On Shuswap Lake, BC, Canada. You push it aside to open. It automaticly latches again when closing. It is a one handed operation. It mounts on the side of the refrigerator and sticks out about 1/2 inch beyound the door. If you know where to order these, I would like to get one. I have tried to copy it with ABS plastic and a heat gun but it is not quite right. |
