jlvickers
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 23, 2006 - 3:53 pm: | |
On the old flxible transit coaches with the 8V/71&V-730 transmission. The V-730 transmission has a small Firestone air bellows for the support for the end of the V-730 transmission. It also has a small air pressure regulator to control the coach air pressure down to around 60 psi? To inflate the above bellows. By any chance does any one have a Flxible parts book that might list the proper part number and correct name of the regulator? Would you be so kind to post the information on the board. Thanks jlv |
David Hartley (Drdave)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 23, 2006 - 7:35 pm: | |
Most of those were replaced with a stock solid rubber mount. It should be the same on most transits that have the V730 in them. The bar it's hooked to is called the transmission support strut or ( bar ) and really doesn't carry much loading.. Check with the RTS guys, someone should have one laying around and they are fairly cheap too... |
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 23, 2006 - 8:53 pm: | |
You could probably get one from NIMCO...talk to Nick. If they have a flex or RTS that uses one, he could probably sell the brace, air bag, and pressure reg cheaper than a bag would cost. |
jlvickers
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, April 27, 2006 - 10:24 pm: | |
The folks at Muncie found the Flxible part number and they had the valve in stock. jlv |
