Replacement panels for GM Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » April 2006 » Replacement panels for GM « Previous Next »
Posted on Thursday, April 27, 2006 - 5:08 pm:
Have any replaced anodized panels on GM coaches? How does the finish compare to original? Pretty close or way off. I realize that the original panel finish changes over time.Also how about reconditioned bumper's finish?
Doug Wotring
Posted on Thursday, April 27, 2006 - 5:46 pm:
What panels are we talking about.
I have a bunch of brand new old stock ( original stuff)
you can't match weathered aluminum easily. can get close and closest with original GM stuff.
other option is International Bus parts reproduction skin
motorcoach1
Posted on Thursday, April 27, 2006 - 6:20 pm:
http://www.focuser.com/atm/anodize/anodize99.html this may give you some ideas on anodize
Frank Allen (Frank66)
Posted on Thursday, April 27, 2006 - 7:37 pm:
i put on a couple from internation bus works they matched pretty good but did not fit very good
Doug Wotring
Posted on Thursday, April 27, 2006 - 8:22 pm:
Another drawback of the IBC pannels is that the flutting is bent not rolled.
Ed (Ednj)
Posted on Thursday, April 27, 2006 - 8:58 pm:
Sounds like you guys need to tell them about this?
Doug Wotring
Posted on Thursday, April 27, 2006 - 9:15 pm:
they know about the bent vs rolled flutting.....cost issue
mel 4104
Posted on Thursday, April 27, 2006 - 10:56 pm:
check with the sheet metal shop in your area as the bigger shops havethe new computor driven rollers that can reproduce the same fluting that is on your bus at a fracton of the pricethe cost that people are asking for GM panels.it is very hard to tell which and the new rolled one have a little lub on them which washs off. i asked for the price on gm pannel and given a price of nearly $400 and the sheet metal shop made the for less than $100.
John Jewett (Jayjay)
Posted on Friday, April 28, 2006 - 10:26 pm:
John R. you should be aware that the body panels on GM Coaches are made from Al-Clad 2024T3 aluminum, and are not anodized. Electric anodizing creates a .0002 to .003 thousandths surface coating, whereas AlClad is a mechanical proces done during manufacture. A fine, pure aluminum powder (usual method) is applied as the aluminum is rolled to the desired thickness, adding a soft, pure, corrosion resistant coating approximately .020 thick. This coating is sacrificial in nature, and gets a fine patina of corrosion on the pure aluminum that stop/slows further corrosion. Some few buses were produced with an anodized finish for service in heavy salt atmospheres, such as Hawaii and other sea coast venues. I believe Don Schwanke had one of these rare Buffalos
To my knowledge IBP's panels are also Alclad, albeit with a much thinner coating than OEM parts. High quality Alclad sheets can be ordered from aircraft suppliers such as Wick's, Aircraft Spruce, Dillsburg, etc. If you live near a major metro area check the yellow pages for local suppliers. For best qualty, scout the various 'Boards for OEM stuff. HTH. Cheers...JJ
