740 trans leaking Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » May 2006 » 740 trans leaking « Previous Next »
Jerry@nc
Posted on Sunday, April 30, 2006 - 7:12 pm:
I just got back from Ga and the back of the bus is almost wet. with trans oil it is coming out the dip stick hole How much crap am I in and where do I start. Jerry
Earl-8-Ky
Posted on Sunday, April 30, 2006 - 7:43 pm:
Sounds like you have got over full. You check it hot and in nutral with the engine running.
Jerry@nc
Posted on Sunday, April 30, 2006 - 7:58 pm:
I did check it just before leaving Ga. it was 1 Qt low. and was having a hard time shifing at 27 mph.
Camill Paul Elbisser (Paul)
Posted on Sunday, April 30, 2006 - 8:38 pm:
A friend of mind bought a used car and we went for a ride in it. Stopped at a traffic light and I saw smoke coming from my side of the hood. The dip stick had shout out of the transmission and oil had belched out onto exhaust manifold catching on fire. Found the vent on transmission to be clogged. Removed vent and cleaned, replaced the vent with on more trouble.
Hope yours is that simple.
GOOD LUCK
Paul
Jerry@nc
Posted on Sunday, April 30, 2006 - 8:46 pm:
I think I am going to call covington in the morring It is time to get a tuneup on the 6/92 anyway
JR
Posted on Monday, May 01, 2006 - 9:12 pm:
Don't know about your HT740, but my HT748 has an expandable end on the dipstick. Trans fluid couldn't get out if it wanted to. Trans fluid would get out thru the vent if the trans became hot.
Good luck with Covington! I've called them in the past and they were worse than no help. Sorta like talking to Beavis and Butthead. Be sure and get an estimate before you start any projects. I've heard of $2-3K spent without pulling the trans?? And in that case, it still didn't work.
Get a trans temp guage and install. Let you know if the trans is cooling.
You may find that a good take-out is a better idea than having a $10K rebuild. HT740s are common...be nice to get a replacement guaruntee in the event it doesn't work correctly. Installing a trans is a one day job...if one knows what one's doing.
You may want to check with Dean's Coach and see what they recommend.
Good luck, JR
