Prevost Champion questions... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » October 2006 » Prevost Champion questions... « Previous Next »
mark (Coolbus)
Username: Coolbus
Post Number: 4
Posted From: 69.68.253.106
Posted on Monday, July 31, 2006 - 7:23 pm:
Just wondering...
Do any of you nuts (and I use the word in a kind way)out there have a Champion that you've converted or are in the process of? Or do you have any firsthand info about these bus's?
I found one for sale, I think it's a 1982, 8v71 w/ a 6 speed manual tranny. Still a seated bus.
Is there anything unique about this bus that would make it more difficult to convert than, say, an MC9?
How much head-room is there? I am not going to do a roof raise. Are the bays as large as the 9?
What are the general construction materials used on the skin and frame? Prone to rust?
Thanks to all for your input. I will consider any and all of your words of wisdom and advice, even though you are all self proclaimed (bus)nuts!
many thanks
mark
Username: Pvcces
Post Number: 972
Posted From: 65.74.70.16
Posted on Monday, July 31, 2006 - 10:57 pm:
You might check the weight. IIRC, some of those were 35 feet and had three axles.
On the other hand, that probably would mean that you wouldn't likely overload it.
For what it's worth.
Suncatcher
Ketchikan, Alaska
mark (Coolbus)
Username: Coolbus
Post Number: 5
Posted on Monday, July 31, 2006 - 11:26 pm:
seating capacity is 47 -
Does that mean 35 foot or 40 foot?
If I'm going to have a 35 footer, it will only have two axels!
Thanks for the heads up, Tom. I was not aware of the 35foot bus's
thanks
Mark
Ron Walker (Prevost82)
Username: Prevost82
Post Number: 236
Posted From: 208.181.210.47
Posted on Tuesday, August 01, 2006 - 12:04 pm:
82 Prevost Marathon (same as Champion)
8" roof raise
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 34
Posted From: 65.150.45.231
Posted on Tuesday, August 01, 2006 - 12:16 pm:
nice lookin' bus. looks like a 40 foot to me
Post Number: 853
Posted From: 64.228.91.3
Posted on Friday, August 04, 2006 - 11:58 am:
Hello Mark.
That 6 speed will be a "W" shift pattern, not an "H", if that is of concern to you.
Just takes getting used to going "next door" on one of the shifts, instead of "across the street"
Someone else chime in here, IIRC, I think it's between 3 and 4, can't remember if it's at the top or bottom the unconventional move is made.
Those who have 'em don't mind, once they get the hang of it, and 6 gears gives you that much more flexibility.
Username: Prevost82
Post Number: 256
Posted on Friday, October 13, 2006 - 12:22 am:
Hi Buswarrior the "next door shift" is 4th to 5th and it's at the top....and yes it's takes some getting used-too
Ron
