Fuel Filters Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » May 2006 » Fuel Filters « Previous Next »
Pat (Proudeagle10)
Posted on Thursday, May 11, 2006 - 11:49 pm:
My 8V71 had Napa fuel filters (spin-on)I took both filters to a oil supply store, to make sure I would get the right ones back. They gave me Fram filters. They must be the wrong ones, they are leaking at the base. Does anybody know the right spin-on's for a DD8V71.
Thanks in advance Pat
Dave Wilson
Posted on Friday, May 12, 2006 - 1:37 am:
Ph3612 Oil Filter
Dave Wilson
Posted on Friday, May 12, 2006 - 1:40 am:
Sorry misread question thought it said oil filter quit using spin on several years ago went back to sock.
Dallas Farnworth (Dal300)
Posted on Friday, May 12, 2006 - 8:04 am:
Here are the cross reference catalogs for a bunch of different companies:
http://catalog.baldwinfilter.com/
http://www.wixfilters.com/filterlookup/index.asp
http://www.fleetguard.com/fleet/en/catalog/index.jsp?catregion=FGUSA&SMSESSION=NO
http://www.fram.com/partsCatalog/index.php#xref
http://www.napafilters.com/filterlookup/
I hope this helps!
Dallas
Ed Roelle (Ed_roelle)
Posted on Friday, May 12, 2006 - 8:06 am:
The spin-on fuel filters that were on my MCI 8 were
Fuel Primary - DD 23518481, AC TP915D, Fleetguard FF207, Baldwin BF580
Fuel Secondary - DD 25014342, AC Delco TP916D, Fleetguard FF206, Baldwin BF581
I did not give you the Fram numbers since they have a poor reputation for quality.
Ed Roelle
Flint, MI
Posted on Friday, May 12, 2006 - 8:13 am:
Fuel Primary S/O - NAPA 3118 Fram P1146G
Fuel Secondary S/O NAPA 3120 FRAM P1147G
Pete RTS/Daytona
Chuck Lott (Chuckmc8)
Posted on Friday, May 12, 2006 - 8:14 am:
Pat, I'm not taking a stand on Fram filters either way here, but it seems strange that they are leaking at the base...I know it's a long shot, but did you make sure that you removed the old gasket from the filter base before installing the new filters,(I've done that) and are they the correct tightness?
There should be a physical reason that the threased mount doesn't compress the gasket all the way around and make a leakproof seal.
If the filters are the correct model and installed correctly and still leak, you should contact Fram and let them know. You should also ask for a refund of your $$$$ from them as well.
Hope this helps.
Chuck Lott
