MCI 24 volt Trailer 12 volt any sugge... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » May 2006 » MCI 24 volt Trailer 12 volt any suggestions? « Previous Next »
Bob Cox
Posted on Tuesday, May 16, 2006 - 7:06 pm:
need some help connecting twelve volt trailor to the bus 24 volt system?
Bob Wies (Ncbob)
Posted on Tuesday, May 16, 2006 - 8:26 pm:
Use the "Search" engine on this board and you'll find, as I did, at least 2 detailed drawings of the way to handle this little dilemma.
I used the info to build mine and it works....GREAT!
Posted on Tuesday, May 16, 2006 - 8:32 pm:
This comes up at least once a month....
1. Add 24v bulbs to the rear towed light assembly, in
thier own 24v bulb holders..
Or
2. Use a portable lightbar on the towd vehicle, with 24v bulbs...
http://www.blueox.us/Accessories/wiring.htm
Or
3. Wire a 12v bulb (at the connector) in series with each 12v circuit.
Or
__________________________
(The relay wizards will fill you in next)
Crane
Posted on Thursday, May 18, 2006 - 11:35 am:
Two 12v bulbs in series on each side will do it. When they burn out, replace both bulbs.
If there is a chance you will use the trailer for 12vdc, then you can mod the circuit for that as well.
Crane
