Bob Cox
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 16, 2006 - 7:06 pm: | |
need some help connecting twelve volt trailor to the bus 24 volt system? |
Bob Wies (Ncbob)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 16, 2006 - 8:26 pm: | |
Use the "Search" engine on this board and you'll find, as I did, at least 2 detailed drawings of the way to handle this little dilemma. I used the info to build mine and it works....GREAT! |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 16, 2006 - 8:32 pm: | |
This comes up at least once a month.... 1. Add 24v bulbs to the rear towed light assembly, in thier own 24v bulb holders.. Or 2. Use a portable lightbar on the towd vehicle, with 24v bulbs... http://www.blueox.us/Accessories/wiring.htm Or 3. Wire a 12v bulb (at the connector) in series with each 12v circuit. Or __________________________ (The relay wizards will fill you in next) |
Crane
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 18, 2006 - 11:35 am: | |
Two 12v bulbs in series on each side will do it. When they burn out, replace both bulbs. If there is a chance you will use the trailer for 12vdc, then you can mod the circuit for that as well. Crane |
