jjrsmp12
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 19, 2006 - 1:01 pm: | |
I have the hydraulic radiator fan motor. I need to replace the large approx. 2" hose connected to the compressor which is belt driven. Where is the drain for the Hydraulic fluid? Also, filling up with what fluid and where? Thanks |
Ron Rutledge
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, May 20, 2006 - 3:29 am: | |
Compressor?...Pump!...follow your other lines...one could go to a tank!...Hyd fluid... |
jjrsmp12
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 24, 2006 - 3:59 pm: | |
I guess there always has to be an a$$hole on these boards. I replaced the leaky end near the fitting. Found the drain for the hydraulic tank. By the way, 20W50 motor oil is Eagle recommended. Pump not compressor, gotcha. |
