larry Higuera
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 29, 2006 - 9:46 pm: | |
what model would a 1974 with 6V92 4 speed be and what can I find out about it |
David Hartley (Drdave)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 29, 2006 - 10:23 pm: | |
A 4108 or 4905 ( Buffalo ? ) Just guessing since you didn't specify what it was you wanted to know about. How many axles? Whether it was a city bus or highway (tour or hound) bus? So far there are probably 10 possibilities but the 6V92 would be a problem unless the bus had the engine changed. Probably actually an 8V71 original. Is it automatic or manual shift? Does the engine sit across the back of the bus? |
larry Higuera
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 29, 2006 - 11:10 pm: | |
The Bus was on Ebay I believe it to be a Buffalo the item number is 4643029209 this is what I know about it |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 30, 2006 - 1:50 am: | |
Larry - Click on my name above to send me a private message. I have some info on this bus you might be interested in. |
larry Higuera
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 30, 2006 - 5:59 pm: | |
Ok I bought the bus it's a P8M4905A893 I believe it is a 40 foot bus as it has 3 cargo bays per side but only one rear axle and should be a 1974 so some of the last buggalo i believe Kevin webb should be able to tell me more. Is this 12 volt? 8 to 10 MPG should be abt right? how big should fuel tank be? should pick it up friday then I will know more hope it makes it back to Quartzsite from San Jose Larry Higuera soon P8M 4905A893 |
Kevin Hatch
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 30, 2006 - 7:18 pm: | |
My '70 4905 is a 24V. It gets around 10 mpg, and has a 145 gal fuel tank. Hope all goes well! Cheers! Kevin Hatch 1970 PD-4905 |
jlvickers
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 30, 2006 - 11:43 pm: | |
P8M4905A893 from GMC to Smith's Charter Bus Service (Royal Coach)Fremont,CA. Fleet number 523 12/1974. Is this 12 volt? No the Bus is 24VDC neg ground. 8 to 10 MPG should be abt right? (6&7 MPG) how big should fuel tank be? It could have the(optional)larger fuel tank 165 US gallons. I think the standard tank was 135 or 145 gallons. There was a total of 2028 P8M4905A coaches built. The last Buffalos were the H8H-649 and there were only 233 of these coaches built. jlv |
