James T
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 06, 2006 - 10:58 pm: | |
Can someone please tell me the reason a miter box from a 6v92 will not work on a 8v92 the book shows two different boxes.Thanks for any info you can give |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 07, 2006 - 2:33 am: | |
I'd suppose that the different horsepower and torque require bigger gears for the 8V92 unit. |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 07, 2006 - 2:41 am: | |
James are you talking about a 'drop' or 'mitre' box? |
Jim Shepherd (Rv_safetyman)
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 07, 2006 - 10:05 am: | |
Since the 8V92 is longer than the 6V92, I would suspect that the mounting and/or the coupling is different to accommodate the length difference. The fan and AC loads should not be significantly higher. As far as the drop box is concerned, I think they were all the same including the Series 60 installation in the last couple of years of production. Jim Shepherd Evergreen, CO ’85 Eagle 10/Series 60/Eaton AutoShift 10 speed transmission Bus Project details: http://www.rvsafetysystems.com/busproject.htm (updated 2/9/06) (Message edited by rv_safetyman on June 07, 2006) |
James Taylor
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 07, 2006 - 10:16 am: | |
Niles I am talking about the mitre box that drives the fan, air cond and alt sorry about the spelling |
jjrsmp12
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 07, 2006 - 3:10 pm: | |
That's odd, I have a 1991 Eagle Model 15 with 6v92T and I do not have a drop box. I have an Allison HT746 directly coupled to the differential. |
