Eagle 10 Posted From: 24.198.196.56
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 02, 2006 - 11:49 am: | |
The good news is that I finally found the oil leak after 5,000 miles and many searches. The leak is on the top of the engine towards the front on the drivers side. I pulled the floor panel under the bed and it is a steel line that connects the front of the blower ??? and another unit. The end towards the rear of the unit seems to be a brass connection. The end towards the front seems to be a steel pipe fitting that threads into a round unit.It is about two inches long. It is on a 6v92 turbo Eagle 10. I put liquid steel on the line for a tempory fix. Is this a special Detroit engine part or can I just pull the line and replace it? t |
