DDEC - engine slow accelleration Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » July 2006 » DDEC - engine slow accelleration « Previous Next »
Bill Gerrie (Bill_gerrie)
Posted From: 209.50.74.6
Posted on Monday, July 03, 2006 - 12:34 pm:
Just for you guys with DDEC controlled engines Pete Papas and I have spent several days working on a slow accelleraton problem. What we discovered was the engine wouldn't fuel up till the DDEC sensed some turbo boost. We played with different ways to fool the computer and finally came up with the following solution. By putting a varible resistor between pins "B" and "C" of the turbo boost sensor the DDEC thought that it was getting turbo boost and would take off like a race car. The only problem we encounterd was if you put too low a resistance you would blow a lot of black smoke and that isn't good. With a varible resistor of about 100 ohms you could control the smoke problem somewhat. Your foot does the rest. Also it would help if you put a fixed 75 to 100 ohm resistor in series with the varible one it would insure that you never set the varible one so that the smoke is too bad. This setup didn't affect the top end once the turbo spooled up. I did a road test and it made so much difference it the accelleration I can't believe it is the same engine. Bill
Greg Peterson
Posted From: 71.228.18.37
Posted on Monday, July 03, 2006 - 12:52 pm:
Are you sure the sensor is operating correctly? It may be giving the wrong resistance for boost pressure.
My ISB Cummins has a computer and accelerates very fast. It does not smoke at all and puts out the most fuel it can with respect to the boost pressure. If I put a resistor across the sensor it would screw up the whole program. It has to adjust the injector timing and fuel depending on boost pressure and altitude. (It has a separate sensor for altitude).
This sounds like a bad idea unless you know more about the DDEC computer program.
Posted From: 72.40.3.160
Posted on Monday, July 03, 2006 - 3:02 pm:
Hi
Hi - Good News for DDEC (I-II-II-IV) Owners with poor acceleration from a stop
In talking about 6V92TA's with a painfully slow response when starting from a dead stop only - seems their DDEC is set with
some kind of "smoke control" option - they do not smoke when you mash the throttle down
DDEC I -
Thanks to the work of Butch Williams - Luke at US Coach stocks an EPROM replacement for approx $100 that will cure most N.J. MCI DDEC I of their poor acceleration. DDEC I's have a replaceable EPROMS and are not programable
DDEC II, DDEC III, DDEC IV,
Bill Gerrie and I have worked on this problem for the last few days- Via long distance phone call Between Daytona and Toronto - Thank
goodness for "Unlimit USA/Canada phone plans)
Bill used his PROLINK to verify and test the settings and ideas -
First a little history
The D/D DDEC TURBO BOOT SENSOR
old part#--- 16070629
new part#- 23528418
is a 3 pin solid state IC device
pin A = Sensor Return
pin B = Signal Line
pin C = +5 volt supply line
pin B - operating range - approx .5v to 4.75 - voltages outside this range will cause a DDEC Fault
example
pin B @ 1.00 volts = approx 00 PSI Boost
pin B @ 2.25 volts = approx 10 PSI Boost
pin B @ 3.80 vollts = approx 20 PSI Boost
<>The PROLINK was used to verify the correct action of Bill's TBS without the modifications
<>Bill came up with a unique solution - A 100 ohm resistor between pin B (sense line) and C (+5 volts) - will pull up the voltage at the sense line (pin B) to what would be an approx 4-5 psi boost voltage level (as measured/verified with the PROLINK)
<>AS the actual boost pressure increases past 5 or 6 PSI the pull-up effect goes away - allowing normal TBS voltage levels
<>AT full boost the pull-up resistor has no effect
<>The net result is that the DDEC thinks that there's is a little boost pressure available at IDLE and allows for more fuel to be
delivered to the injectors upon acceleration
<>This does mean that if you mash the pedal - you will produce some black smoke - adding a 100 ohm potentiometer to the existing
100 ohm resistor will help you dial out excessive smoke - or - just use the throttle pedal wisely (especially in front of the smog control guys)
<>Idle still remained smoke free
Pete RTS/Daytona
Your results may vary - use at your own risk !!
(Message edited by pete RTS/Daytona on July 03, 2006)
motorcoach1
Posted From: 66.147.114.58
Posted on Monday, July 03, 2006 - 3:50 pm:
Pete I think Eagle-research.com makes a unit that will work . It is used in Hyrdroboost systems to fool the oxygen sensor and emulates a signal , it's switched at the dashboard so you can resume normal engine habits.
Posted on Monday, July 03, 2006 - 8:00 pm:
motorcoach1 -
Please supply a link to the device your talking about at eagle-research.com
If it's thier " brown's gas electrolysis hydrogen oxygen device" - I have a bridge in Brooklyn that I'd like to sell you.
Pete RTS/Daytona
motorcoach1
Posted on Monday, July 03, 2006 - 8:35 pm:
if i can find it in my schematics it's a little circuit that goes in the sensor line to the oxygen sensor , it's fairly simple to build one. i heard Summit Racing has something like it too but have never looked . but it works like i said. in a gas engine it leans it out , in your case it advances the boost
motorcoach1
Posted on Monday, July 03, 2006 - 8:53 pm:
Pete.. i sent you the diagram of the devise to your Email
Greg Peterson
Posted on Monday, July 03, 2006 - 9:46 pm:
The other concern I would have is what is the 100-ohm resistor doing to the sensor. I don’t know who makes the sensor but there is a good chance that it is a Motorola device (now Freescale) that is a strain gauge with built in temperature compensation and amplification.
It looks like the 100-ohm resistor could be adding 20 to 35 ma in order to pull the voltage up from 1 volt to maybe 1.5v to give you the higher reading. The old sensors I used of this type had a MAX supply current of 10ma. They had a precision op amp on the output and had a test circuit load of from 10K to 50K. If it is this type of sensor you could be moose-ing the sensor and that could lead to eventual failure.
You might try designing a resistor ladder network to give you the correct offset and matching. Another method is to add an op amp circuit with built in offset to give you the desired effect. You could even add some non-linear gain in order to achieve the max fuel where you want it.
I don’t want to seem too critical of your effort and I am only trying to be helpful. Design reviews are part of my job. I try and keep our engineers in China, India, USA, and where ever the next low cost place is at, from causing a big design disaster.
Good Luck
Posted on Monday, July 03, 2006 - 10:01 pm:
MotorCoach1
To the best of my knowledge - Detroit Diesel 2 cycle engines never used O2 sensors
What you sent me was a simple 555 timer circiut to produce a square wave frequency - but it had no input from any type of sensor
I also think you are confusing FORD technology with Detroit/Diesel
FORD use a square wave pulse generating style sensors - like thier MAP (Manifold Absolute Pressure) - which can measure vacuum to boost - Manipulation of a Ford Turbo MAP 3 (3 BAR type for Turbo) would require modifing the freqency of the FORD stock map device
so just exactly where do you think this silly HYRDOBOOST device would work in the D/D turbo Boost sensor circuit ??
Pete RTS/Daytona
motorcoach1
Posted on Tuesday, July 04, 2006 - 2:15 am:
PETE on the oscllica scoop , off the sensors we got a saw tooth image so that brings me to the option of delivering a square pulse to the receiver( ecm or emu ), in order to image the chip set to verify to the prom thats the correct setting . the modulation was from my ity bitty mind that did this but it Maye not work for you. I'm just trying to help. the sensor just well be a resistor Base unit.the MAP sensing unit delivers a 5 volt message the the input as i see it so i think the input would be correct to the prom match calculating in the EMU . i don't want to send bad info but i thought it might be helpfully .. Pete i think your a real helpful person and work real hard to solve these type problems.. ps i'll just never help again ...thank you ..mike .. i'm just wrong all the time ..i'm narrow minded and stupid
motorcoach1
Posted on Tuesday, July 04, 2006 - 2:20 am:
Pete i still respect your input and and engineering skills
motorcoach1
Posted on Tuesday, July 04, 2006 - 2:36 am:
i just want to say Allison has to meet EPA standards and this is not in there best interest to do this thats why it is a slow start to be within the EPA fed standard.. ALLISON GIVES A COURSE FOR 5 DAYS. that you can take it , open to all to want be a tech , that doesn't mean your going to be a mechanic just have some knowledge of the operation.
Posted on Tuesday, July 04, 2006 - 8:33 am:
Motorcoach1
First - Sorry - next time I'll keep my attempt to inject humor into a serious post at a minimum-
But Your comments about Eagle.Research's
"Hydro-Boost" system that uses electroylsis to produce hydrogen and oxygen to increase engine horsepower / acceleration had nothing to do with what Bill and I were working on.
Plus - I can not believe that any system like that can produce more energy output then input - that just defies the laws of physics and common sense
I my humble opinion the HYDRO-BOOST - BROWN's GAS systems - Fuel from Water Systems - are all SMOKE AND MIRROR shows - pure snake oil
The rest of the follow-on posts was my attempt to differentiate between Fords MAP sensors Frequency modulation technology and Detroits Diesels I/C straight 0-5 volt sensor standards - and how devices for one are not compatible with the other
Pete RTS/Daytona
Bruce Larsen
Posted From: 72.20.68.7
Posted on Wednesday, July 05, 2006 - 2:11 am:
In my toolbox I keep - along with some tools - the following:
* Baling Wire (for critical work)
* Golf Tees (for blocking off vacuum lines)
* Old Screwdrivers (for propping open 'things')
You guys scare me.
sassbg (Eagleone)
Posted From: 24.255.214.92
Posted on Thursday, July 06, 2006 - 4:33 pm:
I have a 8V92 DDEC .At Idle Smoke Free .But on the road you mash the pedal and the Boost comes up I Get a lot of black smoke. Do i have a Bad Sensor? OR need more RPM?
Posted From: 72.40.13.76
Posted on Thursday, July 06, 2006 - 6:22 pm:
EagleOne
Patient tell his doc - Doc it hurts when I do this - Doc says - don't do that anymore
Hey Pete - I MASH the pedal down and my bus smokes - Hey Eagle one - don't MASH the pedal down anymore
sorry - just couldn't resist
Put a voltmeter on the center pin of the Turbo Boost Sensor - at idle .5 to 1 volt - at full boost 4 to 4.5 volts
Pete RTS/Daytona
sassbg (Eagleone)
Posted on Friday, July 07, 2006 - 12:23 pm:
Thank you Pete I`ll try that.So if it is not that reading Bad sensor?
Sammy (Sammy)
Posted From: 68.237.213.178
Posted on Friday, July 07, 2006 - 5:12 pm:
Eagleone, even though you have an electronically controlled engine you must always do basic mechanical checks first.
Check the air filter,housing,clamps and hoses for air intake to engine.
Good luck.
Sammy
jjrsmp12
Unregistered guest
Posted From: 64.56.98.158
Posted on Monday, July 10, 2006 - 9:23 am:
I picked up a potentiometer and some additional 150 and 220 ohm resistors yesterday. I'll try some additional testing this week. Per Greg Peterson, I am also wondering what the additional amperage is doing to the circuit. Has anyone run this way for an extended period of time? It would be nice to know someone has 200K miles on this mod and no problems:-)
keith d dyson
Unregistered guest
Posted From: 86.130.130.153
Posted on Monday, July 10, 2006 - 9:46 am:
hi there i played around with the turbo sensor in the uk to make our racetruck work better .this is what i did i cut the cable fron the return of the turbo sensor and connected it to the return of the throttle sensor so that when you push the throttle down the ecu automatically thinks there is turbo pressure .ddec 2 also takes a barometric reading when the ignition is switched on thru the turbo sensor you can fool this by having your foot hard down on the throttle to simulate higher/ lower altitudes when turning ignition on. release after turning on ignition engine works just fine although you could still black smoke if you buried the throtttle down hard hope this helps
keith d dyson
www.btra.org
Sammy (Sammy)
Username: Sammy
Post Number: 54
Posted on Tuesday, July 11, 2006 - 5:45 pm:
Hello Keith.
How's the "hot rod' doing this season?
Sammy
Username: Pete_rtsdaytona
Post Number: 251
Posted From: 72.40.12.34
Posted on Wednesday, July 12, 2006 - 4:15 pm:
Keith
you wrote--> "hi there i played around with the turbo sensor in the uk to make our racetruck work better .this is what i did i cut the cable fron the return of the turbo sensor and connected it to the return of the throttle sensor so that when you push the throttle down the ecu automatically thinks there is turbo pressure .ddec 2 also takes a barometric reading when the ignition is switched on thru the turbo sensor you can fool this by having your foot hard down on the throttle to simulate higher/ lower altitudes when turning ignition on. release after turning on ignition engine works just fine although you could still black smoke if you buried the throtttle down hard hope this helps keith d dyson"
I'm confused (kind of normal for me )
I don't understand - you connect the
TURBO BOOST SENSOR return (A pin - which normally goes to ->circuit 452 / DDEC pin y2
to
THROTTLE Position Sensor (A pin - circuit 952 / DDEC pin C3
what difference does that make - still goes to return or ground ??
what am I missing here ??
does the "mashing your foot down to fool the DDEC only work with your wiring change ??
Pete RTS/Daytona
keith d dyson
Unregistered guest
Posted From: 86.143.231.199
Posted on Thursday, July 13, 2006 - 12:30 am:
sorry folks in the uk return means different to you guys +gals .
we call return earth .
the cable that you want is not the 5 volt supply or the return/earth but the other one .
sorry i havent got my wiring diagrams to hand or i could give you exact pin numbers and cavity numbers.
hi sammy i have been rushed off my feet this year with work and i havent had much time for the truck .improvements where made for the first race .new turbo was bought , first time out next week in germany hope it all goes well will email you soon
