Air pressure Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » July 2006 » Air pressure « Previous Next »
Eagle 10
Posted From: 152.163.100.138
Posted on Thursday, July 06, 2006 - 10:32 am:
On my 1984 Eagle 10,the rear air gauge on the dash sometimes only reads about 100 pounds. It also will read 120 at other times. I tap on it thinking it might be stuck but with no luck. It just started doing it recenty after 81,000 miles of driving it. Any ideas?
Bob Greenwood
Posted From: 63.232.213.115
Posted on Thursday, July 06, 2006 - 12:06 pm:
in the 81,000 miles...have you ever disasembled and cleaned your d-2 air govenor on the side of your air compressor,or,even replaced it for 20.00
J.C.B. (Eagle)
Posted From: 74.128.100.110
Posted on Thursday, July 06, 2006 - 4:03 pm:
I have the same problem but mine is with the front tank. Some times it reads 120 and other times it drops to 100. Haven't had time to really get in to it but my thinking is it must be the auto drain valve sticking in the front tank.
Brian Brown (Blue_velvet)
Posted From: 67.174.112.202
Posted on Thursday, July 06, 2006 - 4:06 pm:
Variable air pressure is normal operation on a coach. The governor should keep air pressure within the 90-120psi range. At 120psi, your compressor unloads, meaning it quits adding pressure to the tanks. It should kick back in at 90psi. The air suspension and other air assessories use air while you're running down the road.
You should routinely do a DOT pre-trip test (you can Google the term for untold pages of free info) to insure normal operation of your governor/ air compressor.
HTH,
Brian Brown
Posted From: 71.195.113.23
Posted on Thursday, July 06, 2006 - 10:47 pm:
Brian Brown said - "You should routinely do a DOT pre-trip test (you can Google the term for untold pages of free info) to insure normal operation of your governor/ air compressor."
Don't have to Google at all - there's an excellent generic pre-trip inspection guideline right here on BNO in the "Articles of Interest" section!
Bob Greenwood
Posted From: 63.233.41.91
Posted on Friday, July 07, 2006 - 12:17 am:
and everybody but Brian knows the smoothest rideing bus ever made,has no air suspension
