Justin Dortignac (3of14)
Registered Member Username: 3of14
Post Number: 14 Registered: 2-2005 Posted From: 71.110.189.28
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, July 11, 2006 - 9:19 am: | |
What do you recommend for hydraulic fluid for powersteering, cooling fan...? You may remember that I addressed this before...What would make my air system blow off at 150psi (not at all when cold) instead of 120? (I replaced the governor on the compressor to no avail) Thanks in advance |
Bob Greenwood Unregistered guest Posted From: 63.233.85.164
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, July 11, 2006 - 11:32 am: | |
blow off???? it's NOT supposed to get to 150,change your D-2 air govenor |
Tim Jones (Torquester)
Registered Member Username: Torquester
Post Number: 87 Registered: 12-2000 Posted From: 205.169.164.69
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, July 11, 2006 - 5:31 pm: | |
1. Power steering fluid (NAPA etc.) or automatic transmission fluid, it depends upon what the manufacturer specifies. 2. I'd suspect a faulty gauge if the new governor was adjusted correctly. Test your pressure with a calibrated gauge. If your pressure is indeed 150 adjust your governor. |
