Replacing Supercharger with Turbo cha... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » July 2006 » Replacing Supercharger with Turbo charger 6*71 « Previous Next »
Rusty Thompson (Rusty)
Username: Rusty
Post Number: 37
Posted From: 12.191.99.42
Posted on Sunday, July 30, 2006 - 6:30 pm:
Unfortinatly I don't know a lot about how the 6-71 works, but I do know that even though the supercharger is vital for its operation, it robs a lot of horse power. What I am wondering is what would happen if someone replaced the supercharger with a turbo charger. Just an inocent question that I would realy like an explanation to so no burning please.
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 25
Posted From: 63.233.85.222
Posted on Sunday, July 30, 2006 - 7:10 pm:
it won't start. & the turbo doesn't work till it gets 800 rpm
David Hartley (Drdave)
Username: Drdave
Post Number: 659
Posted From: 67.78.176.54
Posted on Sunday, July 30, 2006 - 8:28 pm:
It's not a supercharger.. It's called a Roots Blower and is necessary to push fresh air into the cylinders which pushes exhaust gases out through the exhaust valves. It also runs the fuel system and injector pump on detroits.
A 2-Stroke is what is called a Scavenger cycle engine. No Intake valves just cylinder ports that the piston moves down to uncover, then the exhaust valves are opended, the air is pushed into the bottom of the cylinder which pushes the burnt fuel (exhaust) out the top of the cylinder. The exhaust valves close as the piston travels up where fuel is sprayed in ... you now know how it goes....
You can add a turbo before the roots blower but would need some serious internal engine modifications which include a lower compression ratio, different injectors and timing changes.
Tim Hoskinson (Tdh37514151)
Username: Tdh37514151
Post Number: 175
Posted From: 4.253.125.2
Votes: 2 (Vote!)
Posted on Monday, July 31, 2006 - 2:04 pm:
Superchargers , blowers same thing start to make boost as soon as the engine is rotated due to being mechanically rotated. Turbos have a lag in the boost due to being drivin by expanding exhaust gases. A two cycle engine would not operate very well with this delay. The problems of driving the aux. drives can be delt with but not the lag problem. Turbos can be added to the intake of the blower and make it run cleaner and produce more hp. Modifications to engine depends on the tubo used. There are many variables involved with how the engine needs to be modified.Some used lower comppression pistons as mentioned others used a reduced gear ratio drive on the blower. Your better off to get a factory made turbo engine if you want to go that rout. Putting one together on your own will require very good info. on all the parts you wish to use.
Post Number: 28
Posted From: 63.233.6.253
Posted on Monday, July 31, 2006 - 4:19 pm:
it's called a roots pump.we used them to pump blood in a beef processing plant. I agree with Tim, If you want something like that,you need to buy one from somebody that knows what goes where & why
Username: Drdave
Post Number: 662
Posted on Monday, July 31, 2006 - 8:38 pm:
The now Famous 671 Superchargers used on custom cars and race engines is derived from a remanufactured Roots blower. The rotors are machined or replaced with closer tolerance rotors usually with a seal vane in the tip edges to provide a maximum seal as the vanes rotate.
The end plates are also either replaced and or machined to handle a heavy duty bearing and pulley to drive them. Lot's of design mods.
The pump a lot of air.... Septic Tank pump trucks that use a vacuum to pull stuff in use an industrial roots blower that creates a vacuum. Vactor trucks use both Vacuum and Pressure provided by root type blower/pumps. Our printing press equipment uses Roots and Vane pumps to make both pressure and vacuum at the same time.
